2000 shee - 30 pilots, needle 2nd pos. from blunt end, 280 mains, prodesign filter, lid on w/o snorkel, tors eliminated, everything else is stock running at sea level. My question is got everything put back together and the right exhaust is completely cold. I checked the compression=120 both cylinders. I don't know what is wrong. bangheadbangheadbanghead Thanks for any help.
I would make sure the choke tube between the carbs is connected. Then pull the left plug wire and see if you can get the right cylinder to fire alone. I had similar problem Sunday, pulled boot on oppostie cylinder choked with hand over intake and started right up, then shut it down and fired up both. I'm sure is unhealthy to run on one cylinder but for a second or two it shouldnt matter.
I think you should have lifted your needle as well.
Edited by DIRTBIKEZ
Check the choke tube, and make sure you didn't leave any rags in the exhaust when you had it apart. I know someone who did that...... B)<_<
