ssbanshee Posted April 12, 2004 Report Share Posted April 12, 2004 My banshee seems slow it has fmf fatty pro desing coolhead and 2into1 filter 28mm flatside carbs with 280 mains and 30 piolts the motor is an 01 just dosnt seem as fast a it should and i get bet by my friends with the same stuff what is up with it Quote Link to comment Share on other sites More sharing options...
banshee76179 Posted April 12, 2004 Report Share Posted April 12, 2004 what is ur compression? where is it slow at? (before or during the power band) Quote Link to comment Share on other sites More sharing options...
ssbanshee Posted April 12, 2004 Author Report Share Posted April 12, 2004 slow in the power i plan on checking the compession tonight do you think i would be the rings the motor is almost 4 years old and it is not like slow slow my friends just pull on me Quote Link to comment Share on other sites More sharing options...
sredish Posted April 12, 2004 Report Share Posted April 12, 2004 slow in the power i plan on checking the compession tonight do you think i would be the rings the motor is almost 4 years old and it is not like slow slow my friends just pull on me if it's 4 years old, and it's been ridden enough, the top end could be worn plenty. do check the compression and let us know where it's at. how do the plugs look, if it's running lean ,sometimes it will seem to run good, but not have as much power as it should. Quote Link to comment Share on other sites More sharing options...
nickxc Posted April 12, 2004 Report Share Posted April 12, 2004 If your compression is up another thing it could be is your crank, A stock crank will twist if it hasnt been welded. I was told that and didnt believe it but I had a banshee that just seemed to get slower and slower and over the winter the only thing I did was have my crank trued and welded and the next spring I was pulling 3 or 4 bike lengths on my friends who where beeting me last year. Quote Link to comment Share on other sites More sharing options...
