Jetting With A Dyna Ignition
Shouldn't have to change anything. Your not changing the airflow or anything else that would affect the air/fuel mixture. Your just affecting how and when it sparks. Just check your plugs after the install to verify whether or not a change is actually needed.
I did go up on the main when I switched to a hotter sparking plug, so just check the plugs, these bikes all run a little different.
Edited by sredish
