I took my silencers off of my T5's to polish them up nice and pretty.....It's the first time i had them off since i bought it last summmer.... I noticed that there is about 1/16 inch of carbon bulit up on the inside of my pipes. I didnt know if that was a bad thing or not.....if it is bad how do i fix it???...shee used to run really rich until i rejetted it...its jetted perfect now...I just thought that i might be losen some power!!
its typical however running different oils can reduce/increase the carbon deposits. i myself am polishing nowusheeitnowudonts exhaust ports so there is less/none carbon buildup on the ports. as for the exhaust i doubt its losing any power from it unless its right where the port meets the pipe.
Run a tank of 114 octane, that'll clean out a lot of carbon throughout the motor...It cleaned my silencer on my streetbike!! :rolleyes:
Ask around, someone will know...Do you have any dragstrips around your area? Small airports will sell it....Anyplace where racing is involved will have it....
