XTShee Posted April 11, 2004 Report Share Posted April 11, 2004 Ok I got my new motor installed, but it is a bitch to start When I got up to the dunes yesterday I took it off the trailer and got it started then crusied around slow for like 20 min, I then pulled up and killed it to let my dad have a go and it wouldnt start again. Checked spark and nothing, tried new plugs and nothing. So after about 30 minitues of playing with shit and getting no where I put it all back together and was ready to leave, I gave it one more kick for the hell of it and it started WTF. I killed it straight away and then tried to start it again but it wouldnt After like another 20 min of stuffing around the same thing I got no idea whats going on. When I rebuilt, I replaced the crank, pistons, clutch, reeds, put on an adjustable timing plate, lightened my flywheel and new carbs along with some other stuff. Before this I still used the TORS system, is there any wiring I have to change that could be causing this? any other ideas? Quote Link to comment Share on other sites More sharing options...
sredish Posted April 11, 2004 Report Share Posted April 11, 2004 Before this I still used the TORS system, is there any wiring I have to change that could be causing this? any other ideas? Sounds electrical. The parking brake could also cause it if the wiring is still installed. Make sure the wires are disconnected from the lever AND from the plug down by the radiator. Even more, be sure all the TORS crap is yanked. Quote Link to comment Share on other sites More sharing options...
XTShee Posted April 11, 2004 Author Report Share Posted April 11, 2004 I disconnected the parking break a long time ago, used one of the block off things Whats the TORS stuff I remove, theres two black boxes below the radiator one has the plug wires going back in to it so i am guessing you mean the other one. Quote Link to comment Share on other sites More sharing options...
XTShee Posted April 11, 2004 Author Report Share Posted April 11, 2004 ok tryed unplugging/plugging that box and it dosnt make a diffrence, could an incorrect pickup coil clearance cause this type of problem? Quote Link to comment Share on other sites More sharing options...
banshee76179 Posted April 11, 2004 Report Share Posted April 11, 2004 Sounds like the Stator or cdi box crapped on you! Quote Link to comment Share on other sites More sharing options...
frocashmoney24 Posted April 11, 2004 Report Share Posted April 11, 2004 yea check ur stator and cdi with a running shee, so you did a spark test and nothing at all? Quote Link to comment Share on other sites More sharing options...
XTShee Posted April 11, 2004 Author Report Share Posted April 11, 2004 Yeah did a spark test and nothing, I checked the pick up clearence and it checks out too along with all the wiring as far as i can tell. Going to bring it in to the shop tommorrow and let them worry about it, its starting to piss me off and if I keep playing with it i am likely to break something. Quote Link to comment Share on other sites More sharing options...
XTShee Posted April 13, 2004 Author Report Share Posted April 13, 2004 Ok heard back from the shop now and it seems they are stumped to. They have found that if you kick the bike over normally it wont spark, but if you keep kicking it over really fast it will start up. Also it is not any easier to start if its hot. Anyone got any ideas? or had this happen to them? Quote Link to comment Share on other sites More sharing options...
XTShee Posted April 13, 2004 Author Report Share Posted April 13, 2004 Ok I got a theory Now since I shipped my flywheel to the states to be lightened with my cylinders it would have gone through all sorts of xrays and scanners and shit. Now for what I've read the flywheel contains all sorts of magnets and shit that work with the stator to create an electrial charge. Could the xray/scanning have disrupted or weakend the charges in the magnets? possabally causing the problem I am having. I am tired and probably talkin a load of but I am running out of ideas Quote Link to comment Share on other sites More sharing options...
stu Posted April 13, 2004 Report Share Posted April 13, 2004 have any of your buddys got shees?? if so just "borrow" their bike for a day and swap over the flywheels to check your theory. if that doesnt work it sounds like youll be in the garage swapping bits till shee fires! thats just shite luck dude stu Quote Link to comment Share on other sites More sharing options...
richwuest Posted April 14, 2004 Report Share Posted April 14, 2004 I would check the CDI box first, with a borrowed known good one to see what happens. My bud had a CDI going out, and it was a bitch to start, and sometimes you would even have to pull it with another bike and pop the clutch to start it. Once the CDI was replace with a new one (aftermarket box of course) it starts and runs fine. Quote Link to comment Share on other sites More sharing options...
superchicken Posted April 14, 2004 Report Share Posted April 14, 2004 IMy bud had a CDI going out, and it was a bitch to start, and sometimes you would even have to pull it with another bike and pop the clutch to start it. Once the CDI was replace with a new one (aftermarket box of course) it starts and runs fine. had the same problem.cdi was bad,made due by bangging on it,but got old real quick.got a dyna fs,reliable starts every time now Quote Link to comment Share on other sites More sharing options...
XTShee Posted April 14, 2004 Author Report Share Posted April 14, 2004 The Bike shop managed to get it running now, it was something to do with the wiring, once I provided them with a clymers manual that had a picture of the wiring harness it all came clear. I got their mechinic to take it for a quick ride around the coast to make sure it was all running sweet. So it looks like I will be good to go for this weekend, touch wood Quote Link to comment Share on other sites More sharing options...
