flea49 Posted April 8, 2004 Report Posted April 8, 2004 I bought a new set of 36mm tm mikuni carbs put them on my banshee and it starts first kick idles great and if you baby it it will rev out but if you punch it its just boggs plum down will not take gas. i have all the goodies so these carbs ought to work,they are still at stock settings 280 main,50 pilot.any ideas? Quote
SDD Posted April 8, 2004 Report Posted April 8, 2004 Thats a large carb for a Banshee motor.... unless you have something like a big bore stroker. What mods do you have? Quote
MADMOOSE Posted April 8, 2004 Report Posted April 8, 2004 u may have to run a bigger fuel line and petcock.... Quote
flea49 Posted April 8, 2004 Author Report Posted April 8, 2004 I have full drag port by hole shot racing,cool head,17cc domes cpi pipes outside,1 to 4 override, Quote
Blue Duece Posted April 8, 2004 Report Posted April 8, 2004 you do need larger fuel lines and a decent tee instead of the stock dia. lines....36's does sound a little steep, ive always found a smaller carb jetted fat works better than a larger carb choked off.....i use a 50 pilot on 34's with a pretty fuel savy port also and its real crisp from idle on up......what are you using for an intake? and reeds?...heres a shot of how i set mine up.... Quote
