Foobie Posted April 9, 2004 Report Share Posted April 9, 2004 OC, I am running the 2-1 pipe and the stock carbs (working on 2-1 carb, thanks to cheezehead!) I was running out my stock gearing something fierce. I also have the casesaver and Blue Duece is right. You can only go up to a 15 front with the saver. I run 15/41 and I run small to medium tracks and 3rd is the money gear. 4th pulls like mad if you can get into it. You never see first. Second only in the tightest of corners. And if you can get into 5th hold on, especially on tacky tracks. If you find that you are shifting too much with 15/41 then go 15/40-38. 15/38=16/41 just in case you want to how it pulls. I am jumping 60ft doubles in 4th with 15/41 so there is plenty of gear with that setup. And that is on a loose loamy track. Dustin Quote Link to comment Share on other sites More sharing options...
