Spark Once In A While
My left fires when it should but theres trouble with the right.I swapped both CDI and coil and still the right side fires intermittenly.I have also tried different plugs.The only thing that has not been checked is the stator.Could it be???
My jetting is fine. TORS is unplugged.
If it was not your coil it has to be the wireing going to the stator or the stator.
Mine was the coil but same problem. Or its the pick up on the outside of flyweel is loose or to far away.
Chech wiring is your pipe hitting it and melting it?
