Minkia38 Posted April 2, 2004 Report Share Posted April 2, 2004 Well I have tons of used spark plugs, and usually once or twice a summer I will sandblast them, regap them, and put them back in the regular boxes, to be reused in the banshee (after i clean all the sand off of course). Now my banshee is much more dialed in, but then someone told me that I should not do this becasue the sand eats some seal away or something, and they are unusable after this. So, i asked before, but never got a sure answer. Is this ok? Quote Link to comment Share on other sites More sharing options...
frocashmoney24 Posted April 2, 2004 Report Share Posted April 2, 2004 ive always heard it was allright, wat seal could it eat? Quote Link to comment Share on other sites More sharing options...
cgamla Posted April 2, 2004 Report Share Posted April 2, 2004 The down side to sandblasting the plugs is that the area between the plugs outer case and the insulator can trap grains of sand. Then you put it in your motor and heat it all up and the sand can come out. Some plugs have a flat area up in there but then some have the insulator nearly touching the outer case. The closer the insulator to the case the better chance of getting sand lodged in there. If I can't clean it out with carb n choke cleaner I spring for new ones. Quote Link to comment Share on other sites More sharing options...
Minkia38 Posted April 3, 2004 Author Report Share Posted April 3, 2004 yup - thats what i do - i dont know what seal they were talking about - it was the guys from Dynoedge racing in Michigan that told me that Quote Link to comment Share on other sites More sharing options...
boonman Posted April 3, 2004 Report Share Posted April 3, 2004 I wouldn't do it. Plugs are cheap. And I can't remember the last time I fouled one in my bike. Actually, the only time I have changed the plugs is when the top end goes.... On a serious note, I change them at the start of every season. That's it. Quote Link to comment Share on other sites More sharing options...
sheerider4life Posted April 3, 2004 Report Share Posted April 3, 2004 Yeah it could work Quote Link to comment Share on other sites More sharing options...
NYUK Posted April 3, 2004 Report Share Posted April 3, 2004 not worth the potential headaches.i ve found once you foul a plug no amount of cleaning it will make it fire right again.i buy them by the box.all the scratch you got and your recycling plugs?jeeeeeeeeeez.ray trump the e bay king. Quote Link to comment Share on other sites More sharing options...
Minkia38 Posted April 3, 2004 Author Report Share Posted April 3, 2004 usually i buy them by the box too, but i have a huge bag of used ones! Sometimes when I dicking around or jetting in a new bike, I will run out of plugs, and then i would turn to the bag of used ones and my sandblaster. I think it works just fine, but then i heard the opposite. The RZ gets nothing but the best Quote Link to comment Share on other sites More sharing options...
2stroker Posted April 4, 2004 Report Share Posted April 4, 2004 Sandblasting the plugs will work but I'm not sure how it will affect performance. By sandblasting the plugs, the edge of the electrode tip will be rounded off a little. I was under the impression that the electrode edge should be sharp for the best spark. If I'm wrong, lemme know. Quote Link to comment Share on other sites More sharing options...
Stuff Posted April 4, 2004 Report Share Posted April 4, 2004 I did this a few times with my Camaro....when I first got it. First time trying to figure out tuning a carb and ended up fouling a few plugs. I sandblasted them but they never really seemed to run all that good. For how cheap they are, I think it is worth replacing them. ...just my experience Quote Link to comment Share on other sites More sharing options...
