WriteTwisted Posted April 1, 2004 Report Share Posted April 1, 2004 K I got's a sparking issue that is caused by the switch inside the black housing the throttle cable runs through above the carbs. Basicly the second I touch the throttle all spark dissapears. I am told that switch is an emergancy throttle cutout, can I just bypass it or will that screw anything up??????? Quote Link to comment Share on other sites More sharing options...
banshdog Posted April 1, 2004 Report Share Posted April 1, 2004 Are you talking about the TORS? you lose all spark? so does the bike stall? Quote Link to comment Share on other sites More sharing options...
WriteTwisted Posted April 1, 2004 Author Report Share Posted April 1, 2004 TORS? I belive so, what does that stand for and what is the exact purpose? Yup looses spark and the bike stalls! Quote Link to comment Share on other sites More sharing options...
Big Blue Posted April 1, 2004 Report Share Posted April 1, 2004 unhook the little black box on the front left side of your gas tank and the connectors on the tors. if that doesnt work you need to unhook your ebrake follow the connector down by the radiator and unhook it there. Quote Link to comment Share on other sites More sharing options...
WriteTwisted Posted April 1, 2004 Author Report Share Posted April 1, 2004 T.O.R.S - Throttle override system - yes/no? Should be a switch in the box and one in the throttle correct? When I was diagnosing it I would disconnect the plugs for the TORS just after the carbs and the spark would dye. Does that mean there is a problem in the switch at the throttle? "unhook the little black box on the front left side of your gas tank and the connectors on the tors" Will doing this eliminate the switch at the throttle? Quote Link to comment Share on other sites More sharing options...
banshdog Posted April 1, 2004 Report Share Posted April 1, 2004 TORS: throttle over-ride system. basically a safety component. it will sense when the throttleis released, and senses if the parking brake is set. in both cases the TORS will not allow the slides to move in the carbs. Quote Link to comment Share on other sites More sharing options...
Big Blue Posted April 1, 2004 Report Share Posted April 1, 2004 "unhook the little black box on the front left side of your gas tank and the connectors on the tors" Will doing this eliminate the switch at the throttle? yes, i unplugged the box and tors(ontop of your carbs) that will eliminate everything Quote Link to comment Share on other sites More sharing options...
WriteTwisted Posted April 1, 2004 Author Report Share Posted April 1, 2004 Right on, Thanx for the tips Quote Link to comment Share on other sites More sharing options...
