Hi, I plan on getting TR-6's this summer. I was wondering since I have FMF Fatty's now if I would have to rejet the carbs when I put the new pipes on or can I leave the jet settings how they are? Are the Toomey pipes much different?
I would try the jetting where it is at first if you buy them, you will probably have to rejet, i personally like the t6's better they are more of a topend pipe, fmfs are more of a mid range pipe.
When you get the pipes they come with the "perfect jet kit" from toomey. Try out the bigger main they give you and you should be fine unless the bike has alot of other mods.
TR6 pipes are the sh!&. all they give you is a 280 & 270 main.thats only for sea level.once you are ready to get your pipes call toomey and tell them where you live and they will give you the right set. :bolt::bolt::bolt::bolt::bolt::bolt:
TR6 pipes are the sh!&. all they give you is a 280 & 270 main.thats only for sea level.once you are ready to get your pipes call toomey and tell them where you live and they will give you the right set. :bolt:  :bolt:  :bolt:  :bolt:  :bolt:  :bolt:
Yes that is what I have in them now, a 280 main.
I've got the t-6's. Stick with what toomey says ans shee will scream!
I run T-6's with the silencer, 280 mains, stock pilot(25), clip on the fourth groove from the top, 2.5 turns out, and 40:1 Klotz. T-6's are a mid to top end pipe. The low end sucks but, when you hit the power band shee will rip your arms off. My buddy has fattys. He gets me off the line and I catch him on the top. Dead race. Depends on what you want I guess. Tommeys sound way better than anything else.
Is it hard to rejet the carbs? I personally never have done this but I hear Toomey gives really clear instructions and and stuff. So I don't think it will be too hard. What I'm really looking for is a pipe that will give me better mid to top-end. What other low-priced mods can I do to help bring back the low-end?
