i just noticed the other day that the head pipes have a little play in 'em. They wiggle pretty easy(when not connected to the silencers). All the bolts are snug , springs are attached, and the o rings are in place.
Is this normal?
also, where the pipe connects to the motor, there's a lot of discoloring. Bluish almost purple color about 6" down the pipe. I've seen a lotta pipes "blue" before but never this deep of a color.. Could i be running too hot, or is this normal??
The pipes are Fatty's (if that matters)
WEIRD, YAMMAHAMMERS BLUED REALLY BAD TOO. HOWS THE JETTING ? ARE THE PLUGS SHOWING A LEAN CONDITION ? AS FAR AS THE PLAT IN THE HEAD PIPES, ARE THE HANGERS TIGHT ? ARE THEY BUSTED OR SPLIT IN HALF ? ITS NORMAL TO HAVE A LITTLE MOVEMENT WHERE THE PIPE SITS IN THE EXHAUST FLANGE BUT NOT ALOT OF IT. IF YOU TIGHTEN EVERYTHING DOWN IS IT SOLID ?
My Gnarlies turn a slight reddish color for the first 4 to 6 inches, before the first bend, and I have held it at WOT for a hell of a long time on some hill climbs. I know that turning a deep blue is from being hotter than red but I cant tell you the exact exhaust temps that it indicates. I believe that the brighter copper brownish color I even hotter and comes after the blue. You might possibly want to go up a bit on the mains to bring the EGT's down a bit.
Was that after Dumont or before?? W/ the jetting he has now??
that was way before dumont, like when he first got the pipes on it, after dumont it seemed to help out alot more then before.
they have always blued since day one when it was rich
i know 4 guys with bikes from alba and jeted by trinity and they are all blue also mine are the worst(if thats a word) i think i did not wipe mine down well enough after instal and that caused the discolor
That's it(stock hangers)....The rubber middle is getting a little old and starting to crack and brake up, allowing the pipes to move. Thanks Evil.
I'll have to pick up some new ones.
As for the jetting, it was spot on(or so i thought) when i rode it out here, but took it to Dumont this past weekend, and ran like it was lean...not bogging..it kinda felt like it was "holding back". I changed a few things around tonight and am gonna take 'er out for a morning run and see how it is. I'm gonna have to pick up some extra plugs, so i can do a chop.
I had 25 pilot 280 main running proflo and the lid
went to 290 no lid and 27.5 pilot
then 30 pilot dynojet needles and a 300
now i am back to stock needle 25 pilot and a 290
There is one thing for sure, I had to go down 4 jet sizes when I got home from Dumont.....I live 1 mile from the ocean, so I know I'm at sea level...Dumont has more air density then Maine for some reason, so if anyone is traveling to Dumont, then your jetting may be off compared to home.....
