No Bottom End
I'd go to a 52 on the pilot (seeing that you have no airbox lid) and see how that works. You might have to back off a little, but I'd bet that 50 is pretty damn close. Also bump your needle to the 4th clip from the top/blunt end, that will help your midrange considerably.
This will help you see what jets/needles help what throttle area.
i had a 175 main in and got a 160 just to see if i was rich nad it seems to have gotten better on the bottom so i need a smaller main jet. Even though the main is for the top end it still controls a big amount of the gas that your motor sucks up at all throttle positions. I think i should try bigger and smaller pilots to gain a decent bottom end. Trinity told me that the carb comes very fat and rich so im pretty confident on the smaller jet sizes. Ill also try the 4th needle setting and ill post my results from there.
I think i should try bigger and smaller pilots to gain a decent bottom end.  Ill also try the 4th needle setting and ill post my results from there.
It's all in those two sentences. Bigger pilot and fatter needle position, and poof, you'll have bottom end.
Good luck.
