I Have Some Questions
The J-arm frames were I beleive 87,88, and 89. 89 might have been the first year of the A-arms. I'm sure someone will chime in to confirm that. The J-arm only had one attachment point on the top, weaker, but I have heard that they are lighter. I've just never seen them both on a scale. You can get an A-arm retrofit kit for it, Meat "used" to make them, he might still.
TORS is the throttle overide system, kind of a pain in the ass, but easily removed with a readily available kit. It will alledgedly(sp) shut down the motor in the event of the throttle getting stuck wide open.
broke
yea tors is a pain in the ass, and many people remove them before they do anything else, i think they had jarms from 87-91? meat still makes the kits and are for sale on www.thebansheezone.com j arms are known to bend easily, lots of people use them for drag racing or duning because they dont get as beaten as they do in the trails n tracks
thanks for the info. That conversion kit requires welding, my dad can weld, but hes not the best at it, so i dont know if it would be strong enough. Do you think a local shop could do that? Would I really need a-arms over j-arms, are they really that much better? Kevin
To answer your question of "are they that much better".....Yamaha switched to full upper a arms back in 89, so I would say yes. I would just dig around in the phone book. Its not like its going to take all day to weld the kit in. Expect to pay a shop rate, or minimum though. It would be worth it.
Ive seen a few of the j arm banshees around that have been running since the 80's with no bends. If you dont run into shit you prolly won't bend one. Its not as strong as A arms but keep it on the trail and I think you'll be fine.
