zR2 Posted March 27, 2004 Report Share Posted March 27, 2004 i've seen many people talking about drillin their rear axle carrier and puttin in a zerk fitting but what type of greae are oyu guys using in there. I work at a garage and our oil company just sent down some new synthetic wheel bearing grease. This stuff is so thin that to pack a bearing all ya have to do is dip it in this stuff pretty much and it coats incrediably well. Its almost like a very heavy oil. When we do the bearings in trailers with this stuff we fill the carrier with this and then put our seals in. The reccomended miles before changing or repacking 100,000miles. I was just wonderin if anybody has tryed this on a quad as soon as i replace my bearings i am gonna try it hopefully it will make the bearings last alot longer. Any opinions Quote Link to comment Share on other sites More sharing options...
nate1999mxz600 Posted March 27, 2004 Report Share Posted March 27, 2004 sounds like a hell of an idea. i use synthetic grease on my sled and it works real good. but wheel bearings are a kinda different though Quote Link to comment Share on other sites More sharing options...
erbilabuc Posted March 27, 2004 Report Share Posted March 27, 2004 a "liquid" grease wouldnt really work too well. The grease not only lubricates but it also makes barrier to keep stuff out and all the "liquid" grease you are talking about would do is mix with any dirt that might unfortunately get in there. Quote Link to comment Share on other sites More sharing options...
evil Posted March 27, 2004 Report Share Posted March 27, 2004 best stuff i used was that bell ray waterproof grease, works well and dont break down easily and seals crap out. Quote Link to comment Share on other sites More sharing options...
squish Posted April 3, 2004 Report Share Posted April 3, 2004 I agree with it being to thin. I put a zerk fitting in too and it works great. I also drilled a hole in the steel sleeve inbetween the bearings to lube the axle so its not hell trying to get it out next time. Quote Link to comment Share on other sites More sharing options...
p8121 Posted April 5, 2004 Report Share Posted April 5, 2004 hey squish do you have a pic of that fitting you put on? sound like a good idea. Also did any metal shavings get in the rear end greese when drilling the hole for the zirk fitting? Quote Link to comment Share on other sites More sharing options...
reas11 Posted April 5, 2004 Report Share Posted April 5, 2004 i just use a lithium waterproof based grease.. most autoparts stores carry it .. Quote Link to comment Share on other sites More sharing options...
wansomordis Posted April 5, 2004 Report Share Posted April 5, 2004 Did you drill/tap it with it all together or did you take bearings out first ?? Quote Link to comment Share on other sites More sharing options...
squish Posted April 20, 2004 Report Share Posted April 20, 2004 (edited) Im sorry for the late reply (out of town) Im going to try to get pics on tomorrow. I thought of it after I took it all apart. Im telling you it was hell trying to get it apart. My rear carrier bearings were shot. It was hard to believe they were turning back their and not making noise. I didnt worry about shavings. I did it while it was apart. I used a 1/4 tap and put lock tight on the threads of the zerk fitting. On the swing arm I put a 45 degree fitting to access it and a 90 degree one on the swing arm. You have to make sure to pull the seals on the inside of the bearings to allow grease to get to them. I drilled a 1/4 hole on the sleeve that goes inbetween the bearings to allow grease to get to the axle. Im thinking 1/4 hole is big enough? I did the same on the swing arm to allow grease to get to the through bolt. My needle bearings were also shot. The carrier almost took a whole tube of grease. I basically filled it untill I felt a little pressure on the gun. I didnt want to pressurize the carrier to the point the seals would pop out of the other side of the bearings. Hopefully I will never have to replace my bearings again after doing this. Atleast it will keep the water and mud out. Peace of mind you know. Edited April 20, 2004 by squish Quote Link to comment Share on other sites More sharing options...
SICK BOY Posted April 20, 2004 Report Share Posted April 20, 2004 I use the same stuff as Evil,BelRay water prof.This stuff is great. Quote Link to comment Share on other sites More sharing options...
squish Posted April 20, 2004 Report Share Posted April 20, 2004 Here is the swing arm 45 one Quote Link to comment Share on other sites More sharing options...
Cotton eyed Joe Posted April 20, 2004 Report Share Posted April 20, 2004 I have this Pennzoil high temp high pressure grease that I use. Don't know where it came from though... I don't remember buying it. Quote Link to comment Share on other sites More sharing options...
squish Posted April 20, 2004 Report Share Posted April 20, 2004 (edited) sounds like aviation grease Edited April 20, 2004 by squish Quote Link to comment Share on other sites More sharing options...
MotulMonsta Posted April 22, 2004 Report Share Posted April 22, 2004 Molybendiumdysulfide is the best grease on the market. Makes your bearings last foerever..My swingarm bearings are over 4 years old along with my axle bearings. Quote Link to comment Share on other sites More sharing options...
