bansheegirl01 Posted March 26, 2004 Report Share Posted March 26, 2004 Does the boost bottle affect the idle? Since I put it on there, my idle will rev high, then go back down, is this because of my new boost bottle? Thanks. Quote Link to comment Share on other sites More sharing options...
boonman Posted March 26, 2004 Report Share Posted March 26, 2004 It sounds like you have an air leak. Check around the intake boots, (the black rubber things that are in between the carb and the cylinder) for cracks or a loose clamp on the bottle inlet. Quote Link to comment Share on other sites More sharing options...
banshee tuner Posted March 26, 2004 Report Share Posted March 26, 2004 Make sure the bottle did noy come off, you are definately running lean. You have to much air for the amount of fuel you have. Quote Link to comment Share on other sites More sharing options...
Toomey Banshee Posted March 27, 2004 Report Share Posted March 27, 2004 They dont do anything. Take it off and throw on your stock cross over tube and be done with it. Quote Link to comment Share on other sites More sharing options...
Holyman Posted March 27, 2004 Report Share Posted March 27, 2004 Air leak would probably account for the improved throttle response you said you felt too. Hate to blow the engine for the sake of a boost bottle. Quote Link to comment Share on other sites More sharing options...
