Ok heres the deal...Im sick of mesing with 2 carbs and I am about to get the Single kit from Trinity. Question 1. Will it work with the stock airbox??
I live in GA and my altitude is about 1000'
I have a 96 shee w/
boysen reeds
FMF pipes and silencers
K&N with outerwears and no lid
Currently running 300 pilots and 25 mains
If I tell them all of this will it come jetted correctly?
Please give me all the info you have before I spend that kind of $$
Thanks in advnace for all of the great help I have received and Im sure will continue to recieve from the experts here
Yes
I have a 96 shee w/
boysen reeds
No. They will put in some jets based on an approximation, but there is no way they can put the correct jets in. Every shee will run a little different, some like it rich and some like it lean. When you get it, you'll have to run it and dial it in the rest of the way. We can help you when the time comes if need be.
I would recommend the 35mm over the 33mm. It will provide more air and allow for more mods in the future. It's a great kit, and will work great with the FMFs you have. It's well worth it and jetting maintenance and troubleshooting is freaking easy and fast, no more syncing, screwing the dual slides and bowls.
There are a lot of past threads on it, do a search and you'll find a bunch.
Later.
