Chain
After rebuilding my shee I put on a new RK 520 KZ chain that a local shop recommended. IT FRIGGIN SUCKED :flush: . After 3 or 4 weekend rides it has stretched past the point of tightening. Are these good chains? What chain would you guys recommend?
Maybe not the chains fault :shootself: , if I initially put to much tension on it could it have caused it to stretch faster?
your sprockets were worn differently than your new chain was. So it stretched to fit the sprockets, was to loose, then you tightened it and it had to stretch again, etc. until it wore the chain out.
Gotta replace both at the same time.
there you go. sprockets are cheap. $14 and $17 for front and rears, or something like that. It's stupid not too change when they're that cheap.
Hey guys, news flash, my wife, I know that sounds werid, but works for RK/Excel here in San Diego. When the new chain is replaced all sprockets should be done too and if you replace just the chain, then you need to sit in the bike and have about 3/8 to 3/4" of up and down movement in the chain. The RK chain is one of the best, I have some predjustice towards it, DID is ok, but to check that your chain running well you must adjust it, and maybe you did not take enough links out of it when you installed it as well. The chains are not exact fit and 3-6 links need to be removed when you install. For more chain info go to
FTMBiz.com
They can answer questions and have a sponsorship program for racers.
Jeff
P.S. Please do yourself a favor and NEVER use PJ1 blue on a chain, it eats up the Orings!!!!!!!!!!!!!!!!!!!
Spend the extra cash and go for the DID X-ring. You won't be dissapointed. The shop probly recomended the chain because it gets a good deal on them. Non-O-ring chains will wear out faster then shit on an ATV, People I know get about 1 or 2 races out of one. They only use them for the lighter weight and less drag...but that was before they found DID's X-ring chain.
