I have a 2003 Banshee. Pc pipes and K&N filter. My jetting is 280 mains and needle and everything else is stock. It will not start for nothing kicking it. Even with choke out. Has to be pop started and then if it sits for more than 5 mins its hard to start again. What could be the problem?
Sounds like the choke tube, make sure the little black hose that connects the 2 carbs together is in place. That is exactly what will happen if its not connected.
Pc pipes are hard to start w/ stock pilots anyways. Throw some 30 pilots in there, you need it...some others have posted, make sure the equalizer tube in conncected and that you haven't swapped the bowls on the carbs..
