midnighttoker Posted March 21, 2004 Report Share Posted March 21, 2004 i am putting on new pistons and i noticed that there are holes in one side of the skirt, does it matter what way those holes face or can i put them either way? Quote Link to comment Share on other sites More sharing options...
bkabina Posted March 21, 2004 Report Share Posted March 21, 2004 If your serious and your refering to the big intake windows,They go towards the rear. Quote Link to comment Share on other sites More sharing options...
bigwill Posted March 21, 2004 Report Share Posted March 21, 2004 Arrow on top of piston points toward exhaust. Quote Link to comment Share on other sites More sharing options...
itsaripper Posted March 21, 2004 Report Share Posted March 21, 2004 One more thing to do before you bolt it all together. Take the rings, one at a time, and put them in the bore. Push them down about half a inch with the piston. Take a feller gauge and see what the end gap is. Should be no less that .014, and no more than .028. If the gap is less than .014, take a small fine flat file, hold the ring between your first finger and thumb, so just a little bit shows and take a few swipes then recheck. If the gap is less than .014 the expansion of the piston in the bore could cause ring to stick. If the gap was more than the .028 you should have bored and got new pistons. Quote Link to comment Share on other sites More sharing options...
