i know to get rid of them but need to ride tpmorrow early am. anyway been idling really high turned idle knobs all the wat c/clockwise till it stoped then backed off 1/2 now it wont idle at all any suggestions on where they shoul be adjusted to
What you did was lower you slides all the way down it choked out the air almost completely. Secondly you surely took your carbs out of sink. It takes a couple of seconds for your idle to react to the adjustment. What you need to do is turn the knobs on the TORS a couple of turns clockwise, evely turn bosh sides. When you get it at a satifactory idle. Next you have to take the air filter off and look into the carbs through the intake. You need to make sure they are even so one carb doesn't take more air in than the other. That isn't a real great description of how to sink the carbs but the general idea. Look in the jetting FAQ, it will tell you more precisely how to do it.
