svtkid78 Posted March 20, 2004 Report Posted March 20, 2004 shee is idling really high pull out choke then it stops but when you put choke back in it starts again. had it jetted right for my mods and have not changed them since, but i did move from jersey to florida. maybe that is the reason? use o-ring for head gasket so i don't think that is it. have a long day of riding tomorrow so any help would be good. Quote
Banchetta Posted March 20, 2004 Report Posted March 20, 2004 Slides are sticking or you have an air leak... PUll the air cleaner and look inside to see if one of the slides is stuck open a little. Also check the junction box where the throttle cable splits.... If the slides are all good, then spray some wd40 around the carb boots to see if you have an air leak. If you do then it'll idle up higher.... Quote
svtkid78 Posted March 20, 2004 Author Report Posted March 20, 2004 i did that and idle did not change i sprayed all around boots head and reeds. Quote
Banchetta Posted March 20, 2004 Report Posted March 20, 2004 What about the slide height?? Did you check that to??? The motor is an air pump, it has to get air in order to rev....your slides must be held up by the cable or something... Quote
svtkid78 Posted March 20, 2004 Author Report Posted March 20, 2004 what about my air screws or idle screw. Quote
svtkid78 Posted March 20, 2004 Author Report Posted March 20, 2004 also if i just barely barely touch the throttle it wants to stall but just then it is fine going through the gears though plugs are pretty caramely too. Quote
Banchetta Posted March 20, 2004 Report Posted March 20, 2004 what about my air screws or idle screw. Try em. They could very well be just a little too high...adjust the idle knobs so the slides touch the bottom of the carb, then turn them back up 1 full turn, this will sync the carbs as well as get the idle very close to perfect... Quote
svtkid78 Posted March 20, 2004 Author Report Posted March 20, 2004 are the idle screws the two phillps on the tors boxes my f'n clymer is in jersey. Quote
svtkid78 Posted March 20, 2004 Author Report Posted March 20, 2004 what ya think i should set air screws to 1/2 out or about 1 1/2 Quote
Banchetta Posted March 21, 2004 Report Posted March 21, 2004 what ya think i should set air screws to 1/2 out or about 1 1/2 Try .5, 1.5, and 2.5 turns out and see which one responds the best to throttle response of the powerband...every shee is a little different so I can't answer that nor could anyone else....I've seen my shee like .5 turn out in my area, but 2 turns out 300 miles north of me...... Quote
"thenewguy" Posted March 22, 2004 Report Posted March 22, 2004 your running lean, adjust the air screw so it not getting all that air. will it ride fine with the choke out? Quote
svtkid78 Posted March 22, 2004 Author Report Posted March 22, 2004 we all wrote in and overlooked the obvious. throttle cable just needed to be adjusted. prob fixed thanks all. Quote
