Nightbreed Posted March 18, 2004 Report Share Posted March 18, 2004 Does any one know what the actual water temp on a stock banshee is? Also, does any one know what the cylinder head temp should run at? Quote Link to comment Share on other sites More sharing options...
fixitrod Posted March 19, 2004 Report Share Posted March 19, 2004 Mine runs between 160 and 190 normally. Quote Link to comment Share on other sites More sharing options...
Lepew Posted March 19, 2004 Report Share Posted March 19, 2004 Banshees don't have a thermostat to keep a constant temp so a banshee will run what you ride it at depending on outside conditions and how you ride. Just don't let it get over the boiling point of your coolant @ 220+ degrees. Quote Link to comment Share on other sites More sharing options...
Nightbreed Posted March 19, 2004 Author Report Share Posted March 19, 2004 thanks, guys, i figured that the top was 220 but wasnt sure, and thanks for the running temp, i replaced the stock pump impeller yesterday and it seems to be in the 180 range constantly. i will ride the heck out of it this weekend and see if shee gets hot. :flame: Quote Link to comment Share on other sites More sharing options...
p8121 Posted April 1, 2004 Report Share Posted April 1, 2004 was it hard doing that impeller pump? I'm thinking of getting one because mine has overheated a few times since I've done a coupple of mods to it. Quote Link to comment Share on other sites More sharing options...
