jonnyrebel2004 Posted March 18, 2004 Report Share Posted March 18, 2004 Here's the deal. I just put a cool head, v-force II reeds on her, and re-jetted the carbs. Well I put her back together and started it up and it and it ran and ideled good, I was getting on it to take it for a test run down the driveway when it started reving up on its on, so I hit the kill switch and killed it. I started it again and it went to reving up again. I dont know what to do. What could be causing this and what can I do to fix it? I leave for Little Sahara tomorrow night and i have to get it fixed by then. Any help is needed. Thanks Travis Quote Link to comment Share on other sites More sharing options...
banshee04le Posted March 18, 2004 Report Share Posted March 18, 2004 Are your slides returning and in sync? Quote Link to comment Share on other sites More sharing options...
jonnyrebel2004 Posted March 18, 2004 Author Report Share Posted March 18, 2004 Yes, I checked and everything looks good there. Quote Link to comment Share on other sites More sharing options...
Wassup350 Posted March 18, 2004 Report Share Posted March 18, 2004 Make sure that there isnt any dirt in the slides and make sure they are in sync. Also take apart the throttle block and make sure that there is no dirt in it. Also go over it with some silicon and seal any holes that may let water and dirt in. I have had this problem also. I usually snap the throttle real quick and the slides go down and it stops revving, or i just kill it. Quote Link to comment Share on other sites More sharing options...
Fireman-hott Posted March 18, 2004 Report Share Posted March 18, 2004 make sure your reed cages are tightened could be an air leak. still have the TORS? You sure the throttle cable isn't sticking? Too tired to think of anymore questions to ask. Quote Link to comment Share on other sites More sharing options...
badcompany Posted March 18, 2004 Report Share Posted March 18, 2004 make sure your air adjustment screw is still there. Mine rattled out on the polaris and i crunk it up in gear. It ran into the woods and ruined my week old paintjob. Quote Link to comment Share on other sites More sharing options...
bigboybanshee Posted March 18, 2004 Report Share Posted March 18, 2004 Did you check to make sure you put the choke tube back on? Same exact thing happened to me and the choke tube was mistakenly left off....happens to the best of us Quote Link to comment Share on other sites More sharing options...
ledofthezep Posted March 18, 2004 Report Share Posted March 18, 2004 Did you check to make sure you put the choke tube back on? Same exact thing happened to me and the choke tube was mistakenly left off....happens to the best of us That's what I was going to ask. If you don't get it figured out, look me up down there this weekend & I'll help ya figure it out. I'm pretty sure the plan is on Friday at 12noon we're going to meet up outside the south campground entrance; meet everyone & ride for a while...and again on Saturday, same time for those who can't make it Friday. Gunna be a blast. Hope to see ya there. Quote Link to comment Share on other sites More sharing options...
bronco91shee Posted March 18, 2004 Report Share Posted March 18, 2004 dumb ?, but did u change ur cable routin w/ the new head? maby thats it, ive done tha b4. good luc peace out Quote Link to comment Share on other sites More sharing options...
fixitrod Posted March 18, 2004 Report Share Posted March 18, 2004 Also sounds like you may have water on the carbs. Do you let it sit outside in the moisture or ran or did you happen to wash it before you rode it. Quote Link to comment Share on other sites More sharing options...
sneeky Posted March 20, 2004 Report Share Posted March 20, 2004 i had a similar problem once i must have pulled on the throttle cable and pulled the outer cable slightly out of the rubber boot on the thumb throttle revved like a .... BANSHEE ha ha silly but maybe Quote Link to comment Share on other sites More sharing options...
