Go to Reading Spark Plugs and that will tell you what to look for.
I had some pictures, but I can't find them. The very outer ring of the plug (end of the threads) should have a dark ring, and the tip of the plug will be a tannish brownish color. Deep down inside the ceramic of the ring, it will be a darker brown.
  • Accelerate at full throttle on a straight
  • Push the engine stop button and pull the clutch lever in to release the clutch
  • Coast to a stop
  • Remove the spark plug
Reading spark plugs isn't too hard to do, but I've read various understandings of how to read spark plugs and it seems there's different schools of thought on this. I always use a lighted magnifying glass of 5X to 10X to better see the tiny deposits. When checking your spark plug, always use a good used spark plug, making sure it's not worn out. A worn out spark plug will have a worn or rounded center electrode and or side electrode. New spark plugs are hard to read accurately for mixture checks, but if you have to use a new spark plug, then make sure to put at least 15 to 20 hard minutes on it before attempting to get a reading. I do my spark plug readings from the base ring at the bottom of the threaded body. The 'L' shaped grounded side electrode that's welded to the base ring will clue you into the heat range as this is the closest part to the piston. The porcelain will clue you into timing and preignition/detonation issues while the base ring will clue you into the mixture. Many people I've talked to and some of the articles I've read simply look at the porcelain color and use that as their sole guide for a proper air/fuel mixture, but I don't agree with that all together and would not recommend basing your jetting decisions solely on the color of your spark plugs porcelain.
Center/Ground Electrode
You want to first carefully look at the grounded side electrode to determine if you've got the proper heat range for your spark plug and this is done by closely examining the color change of the side electrode. If the color of the electrode changes near its end where it sits over the center electrode, then the spark plug heat range is too cold and what you're seeing is the color changing due to the heat transferring too quickly. If the color of the side electrode changes color near where it's welded to the base ring, then your spark plug is too hot and what you're seeing is a slower heat transfer from the side electrode to the base ring, resulting in preignition/detonation issues and most of the deposits will be burned off. Ideally, you want the side electrode of your spark plug to change color at about the half way point, about where it makes it's 'L' shaped bend.
Base Ring
The second thing you want to check is your spark plugs base ring and this will clue you into how your bike is jetted. The color of the base ring itself is close in color to the crown of the piston and what you're looking for here is a nice light to medium brown color all the way around the base ring. If you're seeing a chalky whitish or light grayish color or the color doesn't uniformly go all the way around the ring, then you are running too lean. If the color does go all the way around the ring, but you see dark colored soft dry soot that's heavily spotted on top of the base ring color, then you're running too rich and or possibly have a spark plug with too cold of a heat range. The presence of wet oil or ash deposits is a tell tale sign of possible engine problems such as valve stem or valve guide wear or worn out piston rings, etc, so don't confuse this with a rich mixture that leaves your spark plug carbon fouled.
Porcelain Color
The third thing to check is the porcelain color and this will clue you into preignition/detonation issues. What you're looking for are tiny specs of aluminum on the porcelain, which can be either black or shiny. If the tip of the insulator appears melted, then this is yet another clue to a pre-ignition/detonation problem. The detonation is caused by the air/fuel mixture exploding instead of burning and you may hear the resulting knocking sound from this, particularly when the engine is under a load. The knocking sound heard is actually a shock wave that's disrupting the boundary layer of cooler gasses that cover the internal parts of the combustion chamber, resulting in incomplete combustion. This rapid rise in pressure and temperature exerts extreme force on engine components and can do very bad things such as crack your engines head, crack or put holes in your piston, blow head gaskets, break your connecting rod, damage bearings, seals, etc. This is why you should not base all your jetting decisions on just the porcelain color alone because the porcelain color doesn't tell the whole story. Although the porcelain and base ring colors are similar, the porcelain usually appears lighter in color when compared to the base ring.
1 - Side Electrode
2 - Porcelain Insulator
3 - Center Electrode
I try get my plugs a brown color...Tan is a scary color, I've seen 4-5 jet sizes difference to get the plug to go from tan to brown, but when it does, it happens in one jet size.......In other words, you could go from a 240 mian to a 280 main and not see any difference in color, but when you go to a 290, it changes a lot....thats what makes the tan color so scary....Find the dark brown color..
