midnighttoker Posted March 17, 2004 Report Share Posted March 17, 2004 what is the easiest way to remove the large bolt that keeps the clutch basket on? i cant get a good grip on it because the clutch keeps spining when i try to loosen it. Quote Link to comment Share on other sites More sharing options...
svtkid78 Posted March 17, 2004 Report Share Posted March 17, 2004 either use an impact gun or a flywheel holder Quote Link to comment Share on other sites More sharing options...
McSkinner Posted March 17, 2004 Report Share Posted March 17, 2004 I took all the clutch plates out and put a flat head screwdriver through one of the fingers on the basket and wedged it in one of the notches on the hub. I know I'll catch hell for telling you this, but I didn't have an impact handy and it took me a couple hours and a few failed attempts before resorting to the trusty screwstick. I was kicking myself in the ass for not trying it sooner. Be careful. Quote Link to comment Share on other sites More sharing options...
zilladude Posted March 17, 2004 Report Share Posted March 17, 2004 make a clutch holding tool by riveting a drive & driven clutch plate together. If the engine is still in the bike you just have to put it in gear & hold the brake to loosen it. Quote Link to comment Share on other sites More sharing options...
Schizo Posted March 17, 2004 Report Share Posted March 17, 2004 I bought an impact wrench for 50$ new and was the best tool purchase i've ever made removing those hard to get off nuts like that and the flywheel are SO easy with an impact it will make your head spin. Quote Link to comment Share on other sites More sharing options...
frocashmoney24 Posted March 17, 2004 Report Share Posted March 17, 2004 airgun+bigassed socket+money wrench holding on ur sprocket=poppin that biotch off! Quote Link to comment Share on other sites More sharing options...
midnighttoker Posted March 17, 2004 Author Report Share Posted March 17, 2004 i tried the screw driver method before i posted this thread. hehe. but no luck. i went to try the impact gun and couldnt find a 1 1/4" socket, only a wrench. so ill go buy the socket and hope it will work, thanks for your help.......... Quote Link to comment Share on other sites More sharing options...
SICK BOY Posted March 17, 2004 Report Share Posted March 17, 2004 I bolt a old friction plate and steel plate together,and then hit the nut with a impact gun.Works great . Quote Link to comment Share on other sites More sharing options...
fixitrod Posted March 18, 2004 Report Share Posted March 18, 2004 I bolt a old friction plate and steel plate together,and then hit the nut with a impact gun.Works great . That is the best holding tool. It even works for re-torquing the nut. Just put it in gear and hold the brake.... then put in the clutch and steel that is bolted together and torquer down. Quote Link to comment Share on other sites More sharing options...
