gonzoret Posted March 16, 2004 Report Share Posted March 16, 2004 I have a 93 banshee with light porting, t5, and open air box with k&n. how much could i advance my timing without having problems? i see that +4 is very popular, my bike is used in sand (glamis, dumont). also i will be modifying the stock plate. anything else i should know or do will be helpfull. Thanks guys Quote Link to comment Share on other sites More sharing options...
ledofthezep Posted March 16, 2004 Report Share Posted March 16, 2004 I wouldn't go with anything over +4 unless you got a motor that can handle it. If you were building a drag motor running on alky, with a badass crank & other internals...I'd say you'd be ok. With your mods I'd just go with +4, you won't be dissapointed, I sure as hell wasn't. Quote Link to comment Share on other sites More sharing options...
McSkinner Posted March 16, 2004 Report Share Posted March 16, 2004 Brother Zeppelin, I'm just wondering what octane you run. I'm just getting my bike back together after the winter. I took it from bone stock to what you see in my sig. and haven't run it yet. I hear people talkin bout how they're scared of detonation and all that. I'd rather push my luck than pay 10 bucks a gallon for fuel. Any input? p.s. John Bonham is my God! Quote Link to comment Share on other sites More sharing options...
blue95shee Posted March 16, 2004 Report Share Posted March 16, 2004 I've got about the same mods and I'm anxious to hear the answer to that question. Hey Zep............did you modify your stock plate to advance your timing?? I was wondering how much you can advance with a stock plate modification. That is how I'm gonna do mine but I want to go about 3 to stay on the safe side. Quote Link to comment Share on other sites More sharing options...
gonzoret Posted March 17, 2004 Author Report Share Posted March 17, 2004 thanks for the info Zep. i am also thinking of using 110 or c12, octane which one can i use or should use? i use castor mix, 40:1 since i am in california our pumps only give 91 octane Quote Link to comment Share on other sites More sharing options...
bigwill Posted March 18, 2004 Report Share Posted March 18, 2004 +4 is the majic # for timing advance for stock to modified engines-drag motors go more---------somebody elaburate on this. Quote Link to comment Share on other sites More sharing options...
chris97shee Posted March 18, 2004 Report Share Posted March 18, 2004 I don't mean to be a stick in the mud but i was wondering exactly how to advance timing on a banshee? When i got mine i didn't have to cause it already was, but im getting a new one soon and i was planing on doing it thanks. Quote Link to comment Share on other sites More sharing options...
Brian G Posted March 18, 2004 Report Share Posted March 18, 2004 There is only one way to change the timing. you need to take the stator cover off and then pull the flywheel off. you will see the stator mounted to a plate, that is the plate you need. Pro Design makes the adjustable plate. If you are down on the side of the bike, you to the right where the cases meet together which is right in front of the sprocket. At that point it kind of forms a little line, that is the line you need to set the plate at, right where the cases meet together. so if you wanted to go 4 degrees over you would set the +4 at that line where the cases meet together. But there are 2 more important factors, when putting the flywheel back on, make sure the key stays in the crankshaft!!!! and after the flywheel is back on you need to adjust the air gap between the flywheel magent and the pick up lead on the stator , it is suposed to be set at 0.18 - 0.20 thousands. Hope this helps any guestions you can PM me. But it is pretty easy. Quote Link to comment Share on other sites More sharing options...
99Red_Roostr Posted March 18, 2004 Report Share Posted March 18, 2004 Vitos degree key +4 = $25 the way to go. 99rr Quote Link to comment Share on other sites More sharing options...
ledofthezep Posted March 18, 2004 Report Share Posted March 18, 2004 Sorry guys I lost track of this thread I guess... Brother Zeppelin, I'm just wondering what octane you run. I'm just getting my bike back together after the winter. I took it from bone stock to what you see in my sig. and haven't run it yet. I hear people talkin bout how they're scared of detonation and all that. I'd rather push my luck than pay 10 bucks a gallon for fuel. Any input? I run 91 or 92 octane with Castor 927 @ 40:1 i use castor mix, 40:1 since i am in california our pumps only give 91 octane I know exactly how you feel, only a few places *sometimes* have 92octane...so that's usually what I run too. I've got about the same mods and I'm anxious to hear the answer to that question. Hey Zep............did you modify your stock plate to advance your timing?? I was wondering how much you can advance with a stock plate modification. That is how I'm gonna do mine but I want to go about 3 to stay on the safe side. I had to replace my stator, so I just bought one of their stock wattage stators on an adjustable plate. Advanced the timing +4. You can mod the stock plate to +4, there's a post somewhere on here with pics & info on how to do it....you'll dremel out counterclockwise 1mm for every degree you want to advance. For instance, 4mm would be +4 degrees advance. +3 wouldn't be bad either, like you said; to stay on the safe side...it's up to you, I wouldn't go over +4 unless you have a motor that can handle it. I myself, would suggest modding your stock plate over a degree key, I've heard too many bad things about degree keys. But on that note, I've heard several good things. Never heard anything bad about modding the stock plate or aftermarket adjustable plates. Ride On! Led Zeppelin Quote Link to comment Share on other sites More sharing options...
scotts96fast Posted March 18, 2004 Report Share Posted March 18, 2004 Sorry guys I lost track of this thread I guess... Brother Zeppelin, I'm just wondering what octane you run. I'm just getting my bike back together after the winter. I took it from bone stock to what you see in my sig. and haven't run it yet. I hear people talkin bout how they're scared of detonation and all that. I'd rather push my luck than pay 10 bucks a gallon for fuel. Any input? I run 91 or 92 octane with Castor 927 @ 40:1 i use castor mix, 40:1 since i am in california our pumps only give 91 octane I know exactly how you feel, only a few places *sometimes* have 92octane...so that's usually what I run too. I've got about the same mods and I'm anxious to hear the answer to that question. Hey Zep............did you modify your stock plate to advance your timing?? I was wondering how much you can advance with a stock plate modification. That is how I'm gonna do mine but I want to go about 3 to stay on the safe side. I had to replace my stator, so I just bought one of their stock wattage stators on an adjustable plate. Advanced the timing +4. You can mod the stock plate to +4, there's a post somewhere on here with pics & info on how to do it....you'll dremel out counterclockwise 1mm for every degree you want to advance. For instance, 4mm would be +4 degrees advance. +3 wouldn't be bad either, like you said; to stay on the safe side...it's up to you, I wouldn't go over +4 unless you have a motor that can handle it. I myself, would suggest modding your stock plate over a degree key, I've heard too many bad things about degree keys. But on that note, I've heard several good things. Never heard anything bad about modding the stock plate or aftermarket adjustable plates. Ride On! Led Zeppelin What kind of compression are you running? Quote Link to comment Share on other sites More sharing options...
RZ383 Posted March 30, 2004 Report Share Posted March 30, 2004 I was running Vito's 7 degree key in my Banshee for about a year in a half on a stock motor till my motor blew. Went back to a 4 degree just to be safe though. Quote Link to comment Share on other sites More sharing options...
Domenick Posted October 28, 2019 Report Share Posted October 28, 2019 Can I run +3on a stoke banshee Quote Link to comment Share on other sites More sharing options...
SKEETER Posted October 28, 2019 Report Share Posted October 28, 2019 +11 will give mo powa Quote Link to comment Share on other sites More sharing options...
registered user Posted October 28, 2019 Report Share Posted October 28, 2019 honestly i would try a vitos 7degree key and probly +3 on the plate Quote Link to comment Share on other sites More sharing options...
