Foobie Posted March 16, 2004 Report Share Posted March 16, 2004 I have felt a lot of other quads that have a lot easier thumb throttles then mine. Is there any way to make it easier without changing my carbs to a single? Dustin Quote Link to comment Share on other sites More sharing options...
checkster Posted March 16, 2004 Report Share Posted March 16, 2004 i sanded the edges of my slide springs......its really easy now, but still has plenty of return pressure. youd be suprised how much a good cable lubing will do to! seriously when was the last time you lubed the cables? check Quote Link to comment Share on other sites More sharing options...
ledofthezep Posted March 16, 2004 Report Share Posted March 16, 2004 Have you ever lubed the throttle cable? Lubed the pulley where the throttle attaches? Just a couple suggestions... Quote Link to comment Share on other sites More sharing options...
BansheeBrian Posted March 16, 2004 Report Share Posted March 16, 2004 If you lube the cable try to keep sand away from it as much as you can.Clean the throttle assy. well.Then plug up that drain hole thats at the bottom so nothing can enter.I have heard that snipping a few coils off the return spring helps. Quote Link to comment Share on other sites More sharing options...
Foobie Posted March 16, 2004 Author Report Share Posted March 16, 2004 Thanks for all the suggestions. I have recently lubed my cable. So I know that is not it. It has pullled this hard since I bought it over a year ago. How do I go about sanding the springs? Cutting a couple of rounds off doesn't lighten a spring it just shortens it. Dustin Quote Link to comment Share on other sites More sharing options...
DUNEDEMON Posted March 16, 2004 Report Share Posted March 16, 2004 Cutting a couple of rounds off doesn't lighten a spring it just shortens it EXACTLY, plus it actually increases the spring rate, I won't bore you with the details , trust me - cutting the springs will actually make the spring stiffer. Quote Link to comment Share on other sites More sharing options...
frocashmoney24 Posted March 16, 2004 Report Share Posted March 16, 2004 banshee's do have more push in a thumb throttle, more carbs, more power=harder to push, ever though about a twist throttle, if ur really interested in a single carb setup i can put u in the right direction Quote Link to comment Share on other sites More sharing options...
Foobie Posted March 17, 2004 Author Report Share Posted March 17, 2004 I have been wanting to get the single carb setup but I can never find a descent deal. I still would like to know how to sand the stock springs. Thanks, Dustin Quote Link to comment Share on other sites More sharing options...
MotulMonsta Posted March 17, 2004 Report Share Posted March 17, 2004 Take the return spring out of the thumb throttle housing. Quote Link to comment Share on other sites More sharing options...
BansheeBrian Posted March 17, 2004 Report Share Posted March 17, 2004 It's just what I heard,boys. Quote Link to comment Share on other sites More sharing options...
Foobie Posted March 17, 2004 Author Report Share Posted March 17, 2004 Motul, Does that really help? Dustin Quote Link to comment Share on other sites More sharing options...
sredish Posted March 17, 2004 Report Share Posted March 17, 2004 I have been wanting to get the single carb setup but I can never find a descent deal. That helps quite a bit, plus losing the hassle of syncing and dicking with two carbs. Quote Link to comment Share on other sites More sharing options...
jeffro189 Posted March 17, 2004 Report Share Posted March 17, 2004 tear that thumb throttle shit off and put on a twist throttle. they take a while to get used to but worth it in the end!! Quote Link to comment Share on other sites More sharing options...
Foobie Posted March 18, 2004 Author Report Share Posted March 18, 2004 I don't know about that twist throttle, how easy is it to keep it steady in the rough stuff? Just to let you know I ride MX. Dustin Quote Link to comment Share on other sites More sharing options...
jeffro189 Posted March 19, 2004 Report Share Posted March 19, 2004 it takes a while to get used to it, but it easy to go ever rough stuff when you get used to it. it took me about 1 week of riding to learn how to ride with a twist throttle. just my 2 cents worth. Quote Link to comment Share on other sites More sharing options...
