I just got a front and back lowering kit made by CRJ Performance.I paid $115.00 for the front and back and that included shipping.They are made from alum. and the craftsmenship is real good.
The installation for the back was easy.Take the stock shock link off,remove the bolt inserts,put the inserts in the lowering link (at the hieght you want)and then bolt it back up.The fronts were a little tricky,because I have a-arm skid plates and one of the mount bolts were in the way of the bracket..After 45 mins. I found a angle to slide in the lowering bracket.After that the other side only took a few mins.
The only down side I found is the rear link has no grease zerks.Other then that they look a lot better then the Dura Blue ones,and cost less.I would suggest these guys if your looking for a lowering kit.
There web site is:www.crjperformance.com
