Tranny Problem
i kinda have a proble with my tranny id like to know if any1 can help me
well i had it worked on b4 it started shftin funny 1 day the shifter wouyld stay down after id downshift and id have to click it back up to downshift again then it quit shiftin and it didnt move got that fixed $110 for a dowel pin, screw plate, special screw???, shift spring return shaft, and a lock washer for shift spring return shaft thats what the bill says
now lately its been shiftin kinda hard but now when i downshift into 1st the shifter stays low again this is the only gear it does it in does any1 know anything that can help me cuz im lost
i think the shiftin hard is cuz i need a new clutch becuz the adjuster on the clutch perch is all the way out and it doesnt pull the whole way in is that y it shifts hard
thanx in advance
I think that this is by far the most common problem that people have with Banshees. I make quite a lot of money fixing this problem at $35 a shot. If you would have taken the $110 that you already spent and gotten a manual and some tools you would be money ahead this time. Get yourself a manual and take the clutch cover off of the bike and adjust the shift shaft. That is all that is wrong, and if you are going to stay in this game, you really need to be able to fix at least this problem. Good luck, and have fun.
see i can work on my shee its just that i had no clue what to look for the first time i took off the clutch cover and i found the shift satr and lots of other lil smashed parts everywhere and i said hell no im not a tranny kinda guy i can do everything else even replace the crank lol not the tranny so a manual hmm this seems too easy i have the tools just not the know how lol thanx for the info
