bluefrog Posted March 16, 2004 Report Share Posted March 16, 2004 :flame: Quote Link to comment Share on other sites More sharing options...
bluefrog Posted March 16, 2004 Author Report Share Posted March 16, 2004 I want to know if a rd or rz 350 has a tahcometer or speedometer because i'll purcase the tahcometer Quote Link to comment Share on other sites More sharing options...
bshay20 Posted March 16, 2004 Report Share Posted March 16, 2004 I know an rz has a speedo Quote Link to comment Share on other sites More sharing options...
909 Posted March 16, 2004 Report Share Posted March 16, 2004 RZ has a tach. You'll need to run the RZ Stator because thats where the hookup is for it. You're better off running an aftermarket tach or shift light with the stock stuff. Just make sure the tach is good for a 2 cylinder (harley if nothing else) and it hooks to power, ground, and the trigger off the coil. Quote Link to comment Share on other sites More sharing options...
rzcolobanshee Posted March 16, 2004 Report Share Posted March 16, 2004 You would be wrong 909, 85 and older rz have a mechanical tach Quote Link to comment Share on other sites More sharing options...
350duner Posted March 16, 2004 Report Share Posted March 16, 2004 How about just running a Digitron tach like the kart guys? Quote Link to comment Share on other sites More sharing options...
bluefrog Posted March 16, 2004 Author Report Share Posted March 16, 2004 where can i get those Quote Link to comment Share on other sites More sharing options...
bluefrog Posted March 16, 2004 Author Report Share Posted March 16, 2004 so your telling me that a stock rz 350 tach will hook rite up to a stock banshee (2004)) Quote Link to comment Share on other sites More sharing options...
bluefrog Posted March 16, 2004 Author Report Share Posted March 16, 2004 do u guys have any for sale talkin for cheap Quote Link to comment Share on other sites More sharing options...
cb67rs1 Posted March 16, 2004 Report Share Posted March 16, 2004 so your telling me that a stock rz 350 tach will hook rite up to a stock banshee (2004)) no you have to have the RZ cases to do that, or take the banshee cases to a machine shop and have them modified. then you would also need the drive gears that go inside the cases. Quote Link to comment Share on other sites More sharing options...
bluefrog Posted March 16, 2004 Author Report Share Posted March 16, 2004 do any 1 make aftermarket tachs for cheap Quote Link to comment Share on other sites More sharing options...
421stroker Posted March 17, 2004 Report Share Posted March 17, 2004 To run an rz tach you need the top case of an rz. Maybe check jegs or summit for a tach. Quote Link to comment Share on other sites More sharing options...
akpopeye Posted March 17, 2004 Report Share Posted March 17, 2004 tryin to find an rz myself, but they are exactly right, the top of an rz case has these little gears for the tach, then there is a threaded hole for the tach cable on top of the cases......a complete rz set up is great all around: powervalves, better shift forks, easy tach hookup, and im betting an easy speedo hookup, not sure bout that.... lata Quote Link to comment Share on other sites More sharing options...
bkabina Posted March 17, 2004 Report Share Posted March 17, 2004 There is no machine work involved to run an rz tach on a stock case you just need the gears,shaft and tach drive that goes on the top case.Look at your top case and you will see the black and little white plugs on the piece of the case that comes up in front of the rear motor mount.You have to take those out and that is were the tach drive goes.Behind the clutch side case,the top left hole is were the shaft goes threw.I will post pictures as soon as I get them,so you can see. Quote Link to comment Share on other sites More sharing options...
rzcolobanshee Posted March 17, 2004 Report Share Posted March 17, 2004 You would have to drill out the case where the tach drive comes out and drill n tap a screw hole next to it to hold it in....would be much easier just to get an rz case Quote Link to comment Share on other sites More sharing options...
