Well Fellers Starting To Play With Gears On
Well I took the 14 off and put the 15 on and she runs a little better, well alot better. I don't have to shift as often and I didn't have any power loss at all just faster is all haha. When I get my +4 swing on I will change to a 16 on the front and try that again. I had it on at first but didn't run it much and I can't remember how it did. Can I use my stock brake line with a +4 swing??
I pull a 16 tooth with 22" rear tires, and I'm not pumping no
Passion power. Not the best gearing for short drags, but good
for lond drags and flat out flying. I can wind out 6th no problem,
even in sand. Not sure about the brake line, but I wouldn't think
it would be long enough :unsure:
What gearing are you running in the rear with your 16??
I'm still on the 41 tooth stock rear. I seen that you are running a
38. Would still be comparable if your rear tires are like 20" and
mine are 22" though probably. I'm sure you could pull it with that
motor, it just depends what kind of riding you will be doin I guess.
You got to get a longer chain anyway, might as well try it.
