Rings
Ok. Look at the piston's ports..are they hard edged or rounded? Next look on the underside, can you see casting marks? like a line running down the center? Cast pistons like the stock and pro-x will have rounded ports and be a bit thicker in the skirt. Wiseco pistons will have a thinner skirt and hard edged ports..plus the W is a dead give away. You also are going to have to mesure the bore to see if they are oversized pistons.
I just happen to have a pro-x and wiseco piston sitting right here next to my comp (My engine blowup trophies) Anyways, the pro-x are stamped with a s/n..wiseco has no marks but an arrow an a letter that's worn too far to make out what it is.
