loganskinner Posted March 12, 2004 Report Share Posted March 12, 2004 can i put a tach on my 2004? Quote Link to comment Share on other sites More sharing options...
bkabina Posted March 12, 2004 Report Share Posted March 12, 2004 Yes Quote Link to comment Share on other sites More sharing options...
Minkia38 Posted March 12, 2004 Report Share Posted March 12, 2004 sure ya can! check out the digitron (do a search via google) Quote Link to comment Share on other sites More sharing options...
brugal Posted March 12, 2004 Report Share Posted March 12, 2004 Absolutely!!! Quote Link to comment Share on other sites More sharing options...
loganskinner Posted March 13, 2004 Author Report Share Posted March 13, 2004 is it difficult? can i use an analog tach? Quote Link to comment Share on other sites More sharing options...
bkabina Posted March 13, 2004 Report Share Posted March 13, 2004 Yeah or use the tach and the tach drive from an rz 350 but you will have to split your cases to use the rz stuff. Quote Link to comment Share on other sites More sharing options...
gumby Posted March 13, 2004 Report Share Posted March 13, 2004 i was thinkin bout this can you use a standard automotive tach if you set it for a 4cyl ? it should work cause the engine fires every 180 degrees so what yall think Quote Link to comment Share on other sites More sharing options...
banshe98 Posted March 13, 2004 Report Share Posted March 13, 2004 I was also wondering about putting an automotive tach on my banshee. Just not sure if it would work or not. Quote Link to comment Share on other sites More sharing options...
sredish Posted March 14, 2004 Report Share Posted March 14, 2004 i was thinkin bout this can you use a standard automotive tach if you set it for a 4cyl ? it should work cause the engine fires every 180 degrees so what yall think They may not all fire at 180 degrees though. Surely most inline engine tachs should work. It would be nice to have. Quote Link to comment Share on other sites More sharing options...
akpopeye Posted March 14, 2004 Report Share Posted March 14, 2004 run rz cases if you can...the cases have a threaded hole for a tach, and these two little gears run the tach, they are inside the top half of the case Quote Link to comment Share on other sites More sharing options...
"thenewguy" Posted March 14, 2004 Report Share Posted March 14, 2004 does anyone have any links for installing a tach on a banshee? i would like to put one on if there not too expensive. thanks Quote Link to comment Share on other sites More sharing options...
loganskinner Posted March 15, 2004 Author Report Share Posted March 15, 2004 i cant find anytihng that says how to put a tach on one anywhere, aside from the digtal one... i wantr a small analog one on my bars. qouls one from a streetbike work? Quote Link to comment Share on other sites More sharing options...
scotts96fast Posted March 15, 2004 Report Share Posted March 15, 2004 i cant find anytihng that says how to put a tach on one anywhere, aside from the digtal one... i wantr a small analog one on my bars. qouls one from a streetbike work? I put a tiny tach on $40(i think)It's simple to install...One wire around the plug wire and one grounded.... Scott Quote Link to comment Share on other sites More sharing options...
loganskinner Posted March 15, 2004 Author Report Share Posted March 15, 2004 is that all? you just ground it and then put a wire around the spark plug? whereis a good place to ground to? Quote Link to comment Share on other sites More sharing options...
scotts96fast Posted March 15, 2004 Report Share Posted March 15, 2004 is that all? you just ground it and then put a wire around the spark plug? whereis a good place to ground to? Yep it's simple!!!!Dennis Kirk has them.....Depending how much ya wanta spend they have some really cool ones around.... Quote Link to comment Share on other sites More sharing options...
