midnighttoker Posted March 12, 2004 Report Share Posted March 12, 2004 what is the easyest way to get the crankcase open. i have the engine out of the bike, and i took all of the bolts out and the one on the end of the generator, but i dont know where to go from here. am i just supposed to pry it open or is there a trick? thanks Quote Link to comment Share on other sites More sharing options...
BdBanshee Posted March 12, 2004 Report Share Posted March 12, 2004 There is also a small half moon plate behind the clutch basket, with a bolt going into each half that has to be removed. Then you should be able to tap the case with a rubber mallet and lift the top half off. Quote Link to comment Share on other sites More sharing options...
midnighttoker Posted March 12, 2004 Author Report Share Posted March 12, 2004 do i have to take the generator off first? because it wont budge... Quote Link to comment Share on other sites More sharing options...
Schizo Posted March 12, 2004 Report Share Posted March 12, 2004 (edited) This is the clip thingy that must be removed. You have to remove the clutch basket first. EDIT: Pic was used from www.thebansheezone.com Try to mention where things came from..... THanks!!! Edited March 12, 2004 by boonman Quote Link to comment Share on other sites More sharing options...
midnighttoker Posted March 12, 2004 Author Report Share Posted March 12, 2004 how does the generator come off? i took off the bolt and it wont move Quote Link to comment Share on other sites More sharing options...
Schizo Posted March 12, 2004 Report Share Posted March 12, 2004 Your gonna need to get a flywheel puller, you can get them from most bike shops for about 10 bucks or so. Quote Link to comment Share on other sites More sharing options...
MotulMonsta Posted March 12, 2004 Report Share Posted March 12, 2004 The case is going to be hard to spit. Make a box with 2x4's just big enough to fit the engine in then set the corner on the case on the 2x4 and push down on the crank in spurts until the case splits. Quote Link to comment Share on other sites More sharing options...
brugal Posted March 12, 2004 Report Share Posted March 12, 2004 You should buy a Clymer manual, it tells you all you need to know,for when you put her back together. Quote Link to comment Share on other sites More sharing options...
frocashmoney24 Posted March 12, 2004 Report Share Posted March 12, 2004 yea if ur going somewhere to get a flywheel puller just add 25 bucks and get the manual, i swear its the best thing ive ever boughten Quote Link to comment Share on other sites More sharing options...
boonman Posted March 12, 2004 Report Share Posted March 12, 2004 Clymer manual. It will explain alot in short amount of time.... You need to get all the peripheral equipment off the motor. Clutch, flywheel, stator, top end. It all needs to come off. Then, with the case bolts out, I take a dead blow hammer, and tap on the rear engine mount. This starts the seperation. Once it seperates from that point, it comes apart easy..... Quote Link to comment Share on other sites More sharing options...
