ifit8abansheedontbother Posted March 10, 2004 Report Share Posted March 10, 2004 hey guys i noticed when i take the rear wheels theres a decent amount of left and right play.i was wondering if this is normal?if not do you need a hydraulic press to put the bearings back in?...i wanna start updating my banshee slowly,i wanna work on the suspension first. Quote Link to comment Share on other sites More sharing options...
DUNEDEMON Posted March 10, 2004 Report Share Posted March 10, 2004 If the axle has excessive end play start by making sure your lock nut is tight. If you end up replacing the bearings a press will help. Quote Link to comment Share on other sites More sharing options...
Holyman Posted March 12, 2004 Report Share Posted March 12, 2004 It could also be the pivot bearings. I can get you a set if you need 'em. Quote Link to comment Share on other sites More sharing options...
ifit8abansheedontbother Posted March 12, 2004 Author Report Share Posted March 12, 2004 explain to me about pivot bearings..never heard of em Quote Link to comment Share on other sites More sharing options...
evil Posted March 13, 2004 Report Share Posted March 13, 2004 explain to me about pivot bearings..never heard of em those are the bearings that go in the swing arm where it attaches to the frame at the back of the motor. Quote Link to comment Share on other sites More sharing options...
Holyman Posted March 13, 2004 Report Share Posted March 13, 2004 These... Quote Link to comment Share on other sites More sharing options...
ifit8abansheedontbother Posted March 13, 2004 Author Report Share Posted March 13, 2004 as a matter of fact DUNEDEMON its a good thing u mentioned that cause on the left side it loose as hell thank god for cotter pins.but my ? is do you torque them or just snug em like bearing on the rotors on a car?? Quote Link to comment Share on other sites More sharing options...
MotulMonsta Posted March 14, 2004 Report Share Posted March 14, 2004 Tigher the better. Quote Link to comment Share on other sites More sharing options...
sredish Posted March 14, 2004 Report Share Posted March 14, 2004 hey guys i noticed when i take the rear wheels theres a decent amount of left and right play.i was wondering if this is normal?if not do you need a hydraulic press to put the bearings back in?...i wanna start updating my banshee slowly,i wanna work on the suspension first. Is the axle moving in the carrier, or is the whole axle/swingarm unit moving? The bearings in the carrier are easy to get out and even easier to get back in. I use a rubber mallet type hammer to gently coerce them in. They go right in, no prob. Quote Link to comment Share on other sites More sharing options...
squish Posted April 3, 2004 Report Share Posted April 3, 2004 mine werent that easy. I had to freeze my bearings and torch the carrier. They finally went in after that. Quote Link to comment Share on other sites More sharing options...
