JTQuad Posted March 10, 2004 Report Share Posted March 10, 2004 I see alot of people on Ebay selling banshee/warrior spindles? Are these compatible? I know a few parts are but diditn think these were. Does anyone know? Thanks - JT Quote Link to comment Share on other sites More sharing options...
Big Blue Posted March 10, 2004 Report Share Posted March 10, 2004 not 100% sure but i think they are the same. Quote Link to comment Share on other sites More sharing options...
JTQuad Posted March 10, 2004 Author Report Share Posted March 10, 2004 ok thanks alot Blue, Anyone else? - JT Quote Link to comment Share on other sites More sharing options...
99screaminshee Posted March 10, 2004 Report Share Posted March 10, 2004 they all should be the same warrior raptor yfz450 raptor 350 banshee all use the same front hubs and spindles they all use the same rear hub except for the banshees that had the 4-156 rear bolt pattern not sure which year u can even put banshee spindles on blaster a arms and banshee hubs on the blasters axel Quote Link to comment Share on other sites More sharing options...
MotulMonsta Posted March 11, 2004 Report Share Posted March 11, 2004 The yfz runs a 4 bolt rear sprocket and I belive it has aluminum spindles. The Warrior might have diffrent front spindles due to the diffrent frame design. The angle of the ball joint mounts might be diffrent as well as the tie rod mount. I do belive the hubs will work on all three models though. Quote Link to comment Share on other sites More sharing options...
fixitrod Posted March 11, 2004 Report Share Posted March 11, 2004 I heard the raptor fronts are stronger and a bolt on if you get the whole assembly for both sides.... so I guess that means they're different but will work. Quote Link to comment Share on other sites More sharing options...
brock_fuzzy_69 Posted March 11, 2004 Report Share Posted March 11, 2004 why not look up the parts numbers and see if they are the same Quote Link to comment Share on other sites More sharing options...
