Do It Yourself Porting
shee4202
  • Replies 64
  • Created
  • Last Reply
Top Posters In This Topic
Porting is an art. Don't get me wrong, you may gain some power from using templates... but probably not as much as your gonna want. I bet if I gave 5 builders exact specs, they'd all come out different. The angles inside the transers, the different shapes each builder uses inside each port... it's an art.
Im a do it your self guy, and love to buy tools so I spent about $450 in special tools(foredom flex tool with different hand pieces, burs and sanding drums, ect..) and the race logic templates and did my own. It came out great and really rips, It runs so good that I just started doing a freind's that said compared to two other local builder/porters bikes he got to test drive he loved mines way more with the wide power gain this type of porting gave my quad. I say if your a do it yourself guy with good hand skills go for it, if you don't trust yourself then ask around and like they said don't let price be the deciding factor and make sure it's someone that can work on the transfer port windows as this is where most of the power is gained.
Good porting guys know what works and what doesn't. They can build the engine to suit your taste. A template is going to be a compromise for all-around power (don't get me wrong, I'm sure it's much better than stock). If you want to learn the theory behind porting you should start with the book "Two Stroke Performance Tuning" by A. Graham Bell. The book just plain rocks. It teaches you everything from what do do with all your ports to building pipes to suit your motor to carbs, ignition and gearing. Most of it is geared toward GP type bikes, but they talk a lot about the RZ350 (yay) so it's real similar, and the theory still works for ATV's.
Keep in mind if you want a good set of engine porting tools you'll probably end up spending as much as you would for a shop to do it. But if you want to learn how and do multiple engines it's worth it.
Exactly what 350 duner said the templates will be a tremendous gain over stock but is equal to about a stage 2 port. An engine builder can take more material out and get more power. If you take more out without knowing what to do your engine will not run right. To sum it all up the templates are $89 plus how much you spend on grinding and sanding tools and is well worth the amount of money for the power gains, but an engine builder can get you more for around $450 so you make the call. How much power can you afford?
I say do it yourself. If you are willing to accept the risk..Have at it. That's how you learn. Pro engine builders wern't born, they were made. Trial and error practice and patience. One day they will die and who's going to replace them?
  • 2 years later...
