18 Inch Tires?
if you switch between 18 and 20 inch tires it will change your gearing. your gearing will be taller with the 20inch tires. whether its gonna bother you or not depends on what kind of riding youll be doing with the different tires. if you run the 18s when racing mx, then just dick around while running 20s, i doubt you will notice much.
