Suspension
The lowers are about .625 wider thanthe banshee a arms at the frame mounts. The uppers are the same width. The other problem is the frame design. The banshee is a wider frame making the a arms shorter. The YFZ is a narrow frame making the arms longer. The trouble is when you have a longer YFZ lower on a banshee frame makes for some severe bump steer. The camber would be way off as well. It would take alot of work to make them fit right and not worth the head aches.
if you just install the shocks they'll fit with just a little grinding on the mounts. as far as performance they are a night and day difference. with all the adjustments you can get them set the way you like. all small bumps are now soaked up and the others are sooo smooth. makes you alot faster through the woods, no more getting beat to death going fast. also they look bad ass on the front.
