I Need A Direct Replacement Easy Install Airfilter
K$N sells a cleaning kit for thier filters, you'll need to spray on the cleaner, rinse it off and then oil it with the K$N filter oil. Its all included in thier cleaning kit. Some guys use Simple Green to clean thier K$N. Guess you'd still have to buy K$Ns' oil tho.
Alot of guys think K$N makes the best filters because they cost the most. IMO, gimme a UNI foam filter to protect my engine instead of an overpriced gauze K$N. Do the research before you buy. Theres lots of opinions on "best filters".
here lately i have been hearing that more and more people are using foam filters. i have a k and n in mine now, and i prolly wouldnt change it, but my yfz450 came with a foam one. it seems like it works pretty well and its simple to clean. i think its really all personal preference.
K&N's work good for sand as the sand won't stick to the filter. Foam is better for everything else. real fine dust will pass through a K&N and enter the motor. Over time it will wear everything out. Don't get a stock filter if price isn't a concern. Pro flow makes a damn good kit that mounts inside your airbox and it won't come apart and seals great. I've never had a problem with my pro flow filter kit. I've had the SAME filter for 3 years now...stock ones lasted me about 6 months. Everything else is 2nd rate compared to the filter in the pro flow kit. I've never seen a more durable filter...it's big too and fills up the whole airbox.
Ahhh
Feels good to be in BHQ.
Wanna see the first thread I ever caused to get "locked" :lol:
http://www.yfzcentral.com/invision/index.p...t=ST&f=8&t=5069
Its all about air filters.
Im Tampa450
01 Blue Screaming Banshee-
Do you already have the flange to hose clamp on a new filter? or still the white plastic stocker?
i ride woods and dusty conditions too, with the pro design with foam, and without the lid. haven't had any problems yet. just check it after every ride and clean as needed. B)
