PyRo_ZaCh Posted March 7, 2004 Report Share Posted March 7, 2004 a while ago i posted about how my banshee blew all three lights out at ce.... got to looking there was a loose wire on the voltage regulator cleaned it off and pluged it back in tested it and now its only getting like 2 to 4 volts.... is that right...if its not what kind of problem am i looking at now? Quote Link to comment Share on other sites More sharing options...
sredish Posted March 7, 2004 Report Share Posted March 7, 2004 maybe the regulator is bad. that amount of voltage is not correct. Quote Link to comment Share on other sites More sharing options...
MotulMonsta Posted March 7, 2004 Report Share Posted March 7, 2004 Is that at idle? Or with some rpms on it? Try checking the volts before the regulator to see what it's making. You might have fried a coil on your stator. But I doubt that. It's most likely your regulator Quote Link to comment Share on other sites More sharing options...
sredish Posted March 7, 2004 Report Share Posted March 7, 2004 Is that at idle? Or with some rpms on it? yeah, sorry, i meant to say at optimum rpms, not idle. It won't be making shit at idle. Quote Link to comment Share on other sites More sharing options...
PyRo_ZaCh Posted March 8, 2004 Author Report Share Posted March 8, 2004 at i red line it only hits 3 or 4, i'll check before the regulator when i get the time, thanks so far. Quote Link to comment Share on other sites More sharing options...
