"thenewguy" Posted March 8, 2004 Author Report Posted March 8, 2004 will i need to buy new gaskets when i take this thing apart to find out if its broken or not? let me know im gonna rip it apart again tonight. do i have to take the carbs off to do this? and could someone please explain to me where the pilot get is located? i really dont wanna take the cables from that tors thing off. Quote
cb67rs1 Posted March 8, 2004 Report Posted March 8, 2004 if your pilots are clogged its pretty easy to tell, itwill barley idle then when you give it gas it will die, if you choke it and it runs better then your pilots are more than likely stopped up. and if your tores is bad thats easy to fix, find the wires going to the carbs , disconnect them, then find the wires going to the throttle on the handle bars and disconnect that, then find the wire for the emergency brake(on the clutch lever) and disconnect it, then find the little black box under the gas tank on the left side and disconnect ALL wires going to it. that will eliminate all the TORS. try those 2 and if you still dont have it running you got other probems Quote
"thenewguy" Posted March 8, 2004 Author Report Posted March 8, 2004 so where is that pilot jet located? do i have to take the carbs off to clean them out? im sure some one must know this question? Quote
Nighty Posted March 9, 2004 Report Posted March 9, 2004 the pilot jet is located next to the MAIN jet. you cant see it that goed since its in a tube. i think the jetting faq has a picture of the whole carb setup. Quote
svtkid78 Posted March 9, 2004 Report Posted March 9, 2004 When you clean out your jets use the litttle wire insinde of a bread twist tie or any twist tie. you can use all the carb cleaner you want if there is something really small it wont get it. jets are made to be a certain circumfrence if it is obstructed at all that may be your prob. it seems as if you may need some other help with this instead of doing it alone Quote
"thenewguy" Posted March 10, 2004 Author Report Posted March 10, 2004 keep it simple stupid. lol the carb floater bowls were switched around. started right up on the sixth kick. now its just a matter of fine tuning the carbs witch is my favoret part. thanks for all your help guys. Quote
SICK BOY Posted March 10, 2004 Report Posted March 10, 2004 Six kicks is a bit much.Did you ever get to take a look at your reeds? Quote
MILO Posted March 10, 2004 Report Posted March 10, 2004 keep it simple stupid. lol the carb floater bowls were switched around. started right up on the sixth kick. now its just a matter of fine tuning the carbs witch is my favoret part. thanks for all your help guys. i was surprised nobody mentioned the bowls being switched. that's usually one of the 1st things to check if you've had the carbs off recently and you're having trouble starting. also the equalizer tube. keep that in mind. Quote
