Carburator Size?
I was wondering what carb size would work the best on a 565 10mm stroker motor....right now i have 35mm keihin pwk's that i can use but i wasn't sure if they are enough carb for the powerplant....???
You know, that is one big azz motor. Anyway, I will have to say check out www.planetsand.com. I don't go there very often, but you may get your most accurate info on a big motor like that over there. I personally have never seen a 10mm as most here probably have not. Good luck.
  • 4 weeks later...
