How's your jetting right now? Rich..lean spot on? Run what you got and find out. Then adjust from there.
For a base line to go off for a foam air filter 500 to 1000 elev, 40 to 60 deg:
#30 pilots (27.5 will probably work too), air screws about 2 turns out
Needle 4th clip from the blunt end for the reeds
# 270 mains for lid on, snorkel removed
With Lid Off use 290 mains
If its colder than 40 deg then go to #300 mains (lid off)
If warmer than 80 deg then go to #280 mains (lid off)
Sorry, didn't see the K&N, use 3 to 4 sizes larger on the mains for the previous reccomendations.
Does anyone know what jetting is required when running FMF SST exaust with power core 2 silencers.
I didn't think you could run those 2 together very easy. What kind of brackets did you have to make?
