jnatali4200 Posted March 5, 2004 Report Share Posted March 5, 2004 i have $400 bucks and dunno what to buy plus a 75 dollar gift certificate.....i was thinking maybe some v-force reeds and shock covers but dunno what else to buy...would like some more power....or something that would look good...thanks Quote Link to comment Share on other sites More sharing options...
frocashmoney24 Posted March 5, 2004 Report Share Posted March 5, 2004 you could do a lot for a little price, mill the head, lighten the flywheel, port the reed cages and get some aftermarket reeds, advance the timing and the parts you said for probably 200 bucks, then move on from there probably gonna wanna do the shee suspension cause they have horrible ones Quote Link to comment Share on other sites More sharing options...
brugal Posted March 5, 2004 Report Share Posted March 5, 2004 You can port and polish... Quote Link to comment Share on other sites More sharing options...
. Posted March 5, 2004 Report Share Posted March 5, 2004 tell us what mods you have and what type of riding you do and we'll steer you in the right direction Quote Link to comment Share on other sites More sharing options...
boonman Posted March 5, 2004 Report Share Posted March 5, 2004 I'm thinking along the line of pipes....... Used. And ten you can get the flywheel lightened and machine the head. It will be an animal!!!!!!! Quote Link to comment Share on other sites More sharing options...
jnatali4200 Posted March 5, 2004 Author Report Share Posted March 5, 2004 i already have pipes (D&D)....i ride alot of paved roads,dirt roads, and wide open areas..some sand pits and trails...i run my bike w/ 1 tooth up in the front sprocket and 1 down in the back. i always wanna be able to run on pump gas. (to much money for racing fuel) thanks. Quote Link to comment Share on other sites More sharing options...
bkabina Posted March 5, 2004 Report Share Posted March 5, 2004 Get passionre to port it,Jim's the man. Quote Link to comment Share on other sites More sharing options...
Ducman Posted March 5, 2004 Report Share Posted March 5, 2004 Port that puppy! Quote Link to comment Share on other sites More sharing options...
. Posted March 5, 2004 Report Share Posted March 5, 2004 What mods do you already have? I'd go with a coolhead and bump the compression up a little bit to about 155-160 or so. Get some dual stage reeds great increase in throttle response over stock reeds, timing key, tires if you dont already have good ones for your type of riding....maitenance stuff, brakes if they need it soon, sprockets and chain, etc. If you are on an unwelded crank I wouldnt port it, it could rip the crank apart. I also wouldnt port it until you're sure what you want to do with the engine. Like if you want a stroker eventually, you're gonna have to get portwork done for that stroker, and you want to port transfers for the rest of how the engine is setup, if you want to change something later like go to a stroker, you might want different types of things done with the porting that you wont be able to do because its already been ported. Just things to think about. I just know I'm not going with portwork until I rip into the bottom of an engine. Quote Link to comment Share on other sites More sharing options...
jnatali4200 Posted March 5, 2004 Author Report Share Posted March 5, 2004 is vito's 404 big bore kit any good? i was thinking that....or maybe some bigger carbs...i dunno..i already have D&D cool heads to Quote Link to comment Share on other sites More sharing options...
n2glamis Posted March 5, 2004 Report Share Posted March 5, 2004 its all about the shearer custom drag pipe in-frames or outer frames...way smother flow and power. available from http://www.inlandatv.com Quote Link to comment Share on other sites More sharing options...
locogato11283 Posted March 5, 2004 Report Share Posted March 5, 2004 port work for sure. or you could always save your money and wait until you can build it up really big. save up and send your engine to jim @ passionracing. i hear he builds one hell of an engine. Quote Link to comment Share on other sites More sharing options...
SyNtAxx Posted March 5, 2004 Report Share Posted March 5, 2004 Hey, If your gonna port it...just tell jim you may want a stroker in the futer. I told Jim that when he ported my jugs....and he ported so I can run a stroker in the future.... Port that shit......Passion Racing all the way.... Nick Quote Link to comment Share on other sites More sharing options...
MotulMonsta Posted March 5, 2004 Report Share Posted March 5, 2004 400 bucks ain't going to get you a whole lot. Save it up and do some general maintainence. Nothing worse then blowing 400 bones on a few parts to find out you need to burn a 1000 to fix the other parts around it in order to get those previously bought parts to work right. I wouldn't port the motor until your ready to rebuild. A set of aftermarket reeds won't let you down, but new bushings, bearings, chain and sprockets will be a much better investment. Fix the problems that are bugging you first. Quote Link to comment Share on other sites More sharing options...
