Have I Made The Right Choice ?
i ordered my +2 swing arm, mods ill b geting r, pipes,ported,polished,bored,pistons,carbs,crank,head, maby some other shit i forgot about, i do dunes so... tell me what u think  :huh:
Your screwed!! :P
Actually, you can tell me how you like when you get yours... ;)
Yep..you need to get the shock revalved and stiffer springs(It's a MUST). If you don't you overheat the shock and cause it to either seize up and bend the shaft or blow out on you. Works make a good shock for only 600 bones. It will last you a long time even under heavy abuse. The fronts are a diffrent story.
Demon after I put a +2 on my Banshee I rode it for one weekend in the dunes. After that weekend I knew I had to revalve and respring. Once I had that done it made a world of difference. When adding the longer swingarm on a shock that was already soft just made things way worse. I wanted to buy a swingarm slightly longer but still short enough for big jumps and I settled for the one I got.
dont spend 600 on a new rear shock. you can get the elka revalve kit for like 350. its all new revalving, spring and whatever else it needs to make it up to elka specs. i hear its well worth the money. even my local aftermarket shop recommended it over buying a brand new one. i would try going that route. just call elka, im sure they can give you some info.
