99screaminshee Posted March 4, 2004 Report Share Posted March 4, 2004 i just got my rear cliper back from the shop yesterday it nned a hole tapped out in it and new pads i put in on and i got fluid in it but i cant get a real good bite it wont lock the rear tires up in wet grass it slows ya down after a while if ya pump em up also how does the rear rotor go is it supposed to be shaped like a plate which way should in cuvre into the swingarm or out to the wheel it was off when i got the bike any help is appriciated thanx Quote Link to comment Share on other sites More sharing options...
pimp559 Posted March 4, 2004 Report Share Posted March 4, 2004 You probably still have a little air in the system. Quote Link to comment Share on other sites More sharing options...
checkster Posted March 4, 2004 Report Share Posted March 4, 2004 keep bleeding it, theres most likely air still in there. I use a mityvac, vaccum pump, works great! check Quote Link to comment Share on other sites More sharing options...
99screaminshee Posted March 4, 2004 Author Report Share Posted March 4, 2004 what is a mikey vac and where can i get 1 Quote Link to comment Share on other sites More sharing options...
DUNEDEMON Posted March 4, 2004 Report Share Posted March 4, 2004 Hand held vaccum pump, availible at finer auto parts stores. Quote Link to comment Share on other sites More sharing options...
99screaminshee Posted March 4, 2004 Author Report Share Posted March 4, 2004 ic ic but what i dont get is fluid is commin out and it doesnt have any air bubbles in it im confused this is the first i had rear brakes since i got like yaer ago so this is new to me never had to bleed em b4 Quote Link to comment Share on other sites More sharing options...
DUNEDEMON Posted March 4, 2004 Report Share Posted March 4, 2004 If there's no fluid comming out how do you know ther is no air in the line? If the line was disconnected from the caliper, air has beed introduced to the system, they need to be bled. The mity vac connects to the caliper bleed screw, pump the handle, this produces a vaccum and draws brake fluid out of the resivoir, do this until there is no more air in the line and you're done. Quote Link to comment Share on other sites More sharing options...
350duner Posted March 4, 2004 Report Share Posted March 4, 2004 Also make sure to keep the resivoir full. If you suck any air into the master cyl. or line from the resivoir getting low you get to curse a bunch and start all over. Quote Link to comment Share on other sites More sharing options...
99screaminshee Posted March 4, 2004 Author Report Share Posted March 4, 2004 there is fluid in the caliper when i bleed them no air comes out just fluid could sumthin else be wrong it just got all new seals and stuff in it it works great when u pump em up Quote Link to comment Share on other sites More sharing options...
99screaminshee Posted March 4, 2004 Author Report Share Posted March 4, 2004 also does any1 know wich way the disc is supposed to cure towards the swing arm or toward the wheel is it even supposed to be curved Quote Link to comment Share on other sites More sharing options...
