Painting The Jugs?
Temps vary from about 300 degrees up to 1000 degrees.
And if your cylinders get over 300 degrees the last thing you need to worry about is your paint, lol!
My banshee jugs are painted silver. They look pretty cool, everybody has polished cylinders out there, not too many that are painted. I'm not sure what etching primer is, but if you properly prep the surface and use a high temp paint it should work fine. I've heard of people PC'ing cyilnders too. I'm not sure exactly how much painting of PC'ing them affects cooling, but so far I haven't had problems. On an air-cooled motor I imagine it would be more of an issue.
Give it a try, worst case scenario you'll have to get out the paint stripper and start over.
