Pro Design Intake....jetting?
If you keep the stock airbox lid on you will not need to rejet. You will not be flowing anymore air than what the snorkle will allow through. If you remove the lid then Yes you will need to rejet.
Survey says... BUUUUUUZZZZZ ( X ) wrong answer
If you are jetted for the stock airbox and put on a K&N you will flow more air and need to re-jet whether you take the snorkle off or not. Take the snorkle off which obviously anybody would do and you will definitly need to rejet. The only way you wouldn't have to rejet is if you left the air box exactly the same and went with a foam filter (that flows the same as stock) instead of a K&N.
